| Version: | V8 | ||
| Area: | Text | ||
| Subarea: | Word Processor |
Some text styles only allow a certain line length of text. Need to increase the allowable line length in Word Processor.
The line length is set with the Line Length command by using the key-in:
LL=? will report the active line length
LL= {value} up to 255 will set / change the active length
Left Margin - Right Margin - Text Justification Explained
The Text Editor Ruler is Short
Automatic return after a few words
