Applies To | |||
Product(s): | STAAD.Pro | ||
Version(s): | All | ||
Environment: | N/A | ||
Area: | OpenSTAAD | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group, Shreyanka Bhattacharjee | ||
Problem Description:
How to add comment using OpenSTAAD (VBA)
As of now there is no OpenSTAAD function to add comment in the input editor. But windows functions can be used to perform this task.
This process explained above have been done in the attached .xlsm file.
*Zone Factor=0.36
*Importance Factor=1.2
*Soil Type=hard Soil
*Structure Type=1
You can follow this process to add comment as per your requirement.
The code can be seen by clicking on View Code under Developer Tab.
If you require any OpenSTAAD function to add comment in the input editor, I would request you to post your suggestion in Bentley Ideas Portal
Link to Bentley Ideas Portal Page: https://staadpro.ideas.aha.io/
STAAD model and macro File:
communities.bentley.com/.../IS-1893-2016-Static-Seismic.STD
communities.bentley.com/.../Add-Comment.xlsm
