MSCE SDK中取消了原来V8i下的文字操作来C函数mdlText_xxx,您需要重新学习类TextBlock,它能同时表达文字元素(TextElement)和文字节点元素(TextNodeElement)。
如下代码是一个典型的通过TextBlock创建一个MSCE下的文字的实例:
| createText
TextFieldPtr createField(DgnModelR model)
// "DgnElementSchema" and "ArcElement" are found from ...\MicroStation\ECSchemas\Dgn\DgnElementSchema.01.00.ecschema.xml
DgnFileP pDgnFile = ISessionMgr::GetActiveDgnFile();
//SchemaInfo schemaInfo(ECN::SchemaKey(L"DgnElementSchema", 1, 0), *pDgnFile);
SchemaInfo schemaInfo(ECN::SchemaKey(L"DgnCustomItemTypes_Architectural", 1, 0), *pDgnFile);
DgnECManagerR ecMan = DgnECManager::GetManager();
ECN::ECSchemaPtr pSchema = ecMan.LocateSchemaInDgnFile(schemaInfo, ECN::SchemaMatchType::SCHEMAMATCHTYPE_LatestCompatible);
if (pSchema == NULL)
mdlDialog_dmsgsPrint(L"Can't find identified schema");
return NULL;
//ECN::ECClassCR ecClass = *pSchema->GetClassCP(L"ArcElement");
//ECN::ECClassCR ecClass = *pSchema->GetClassCP(L"LineElement");
ECN::ECClassCR ecClass = *pSchema->GetClassCP(L"Doors");
ElementId elemId = 49064L; // An arc element id
ElementHandle elem(elemId, &model);
if (!elem.IsValid())
return NULL;
DgnElementECInstancePtr pElemInst = ecMan.FindInstanceOnElement(elem, ecClass);
//return TextField::CreateForElement(*pElemInst, L"Length", nullptr, model);
//return TextField::CreateForElement(*pElemInst, L"TotalLength", nullptr, model);
return TextField::CreateForElement(*pElemInst, L"Type", nullptr, model);
void createText(WCharCP unparsed)
DgnModelP pActiveModel = ISessionMgr::GetActiveDgnModelP();
TextBlockPropertiesPtr pTBProp = TextBlockProperties::Create(*pActiveModel);
pTBProp->SetIsViewIndependent(true);
ParagraphPropertiesPtr pParaProp = ParagraphProperties::Create(*pActiveModel);
//DgnTextStylePtr pTextStyle = DgnTextStyle::GetActive();
DgnTextStylePtr pTextStyle = DgnTextStyle::GetByName(L"5mm", StyleIteratorMode::ActiveFileAndLibraries);
RunPropertiesPtr pRunProp = RunProperties::Create(*pTextStyle, *pActiveModel);
//DPoint2d fontSize = DPoint2d::From(2000, 1000);
//pRunProp->SetFontSize(fontSize);
TextBlockPtr pTextBlock = TextBlock::Create(*pTBProp, *pParaProp, *pRunProp, *pActiveModel);
pTextBlock->AppendText(L"This is a ViewIndependent text");
//TextFieldPtr pField = createField(*pActiveModel);
//if (pField != NULL)
// pTextBlock->AppendField(*pField);
//pTextBlock->AppendParagraphBreak();
//pTextBlock->AppendText(L"Second Line");
EditElementHandle eeh;
if (TEXTBLOCK_TO_ELEMENT_RESULT_Success ==
TextHandlerBase::CreateElement(eeh, nullptr, *pTextBlock))
ElementPropertiesSetterPtr setter = ElementPropertiesSetter::Create();
setter->SetColor(3); // 3 -- Red
setter->Apply(eeh);
eeh.AddToModel();
其中注释掉的一些行也都具有特定含义,取消注释能使程序功能更强大,比如,创建带有文字域(TextField)的文字、多行文字等。
