| Version: | 08.11.07.443 | ||
| Area: | Annotations | ||
| Subarea: | N\A |
On editing text in a DGN drawing, MicroStation freezes, crashes and closes.
It happens on all text when using the Word Processor text editor, but when using Key-In or Dialog Box, it will only crash on some of the text blocks.
Issue occurs when using the following:
A message then appears before it crashes, saying “incompatible text editor used”.
Issue is due to the fact that Internet Explorer 10 is being used with Microstation Select Series2.
Reinstall older version of Internet Explorer 8, in order to resolve the issue.
| Original Author: | Derval Canny |
