ISM Revit Plugin v12.01.00.038
Release Date: 14th July 2023
Version: ISM Revit Plugin v12.01.00.038
Support for REVIT 2024
This version of ISM Revit Plugin supports REVIT 2024 and ISM API 9.1
Preview pane functionality restored
The ability to preview the selected ISM File repository has been restored in this version.
Improve accuracy for models with multiple REVIT Shaft Openings
Shaft openings in REVIT punches a uniform opening across floors. Previously, certain arrangements of multiple shaft openings can cause these to be translated as floor members instead. This is now rectified.
Download Instructions
- The recommended approach is to download and install iTwin Analytical Synchronizer here.
-  Alternatively, and for existing users ISM Revit plugin users, ISM Revit plugin can be downloaded and install via CONNECTION Client.
Special Notices
The installation of ISM Revit Plugin will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2022, Revit 2023 and Revit 2024. iTwin Analytical Synchronizer automatically packages ISM Revit Plugin.
