| Version(s): | All | ||
| Subarea: | Loading | ||
| Original Author: | Abhisek Mandal, Bentley technical Support Group | ||
I am modelling a steel building consisting of columns and beams. The floor slab is a non-structural entity which, though capable of carrying the loads acting on itself, is not meant to be an integral part of the framing system. It merely transmits the load to the beam-column grid. There are uniform area loads on the floor (think of the load as wooden pallets supporting boxes of paper). Since the slab is not part of the structural model, is there a way to tell the program to transmit the load to the beams without manually figuring out the beam loads on my own? ?
STAAD's FLOOR LOAD option is ideally suited for such cases. This is a facility where you specify the load as a pressure, and the program converts the pressure to individual beam loads. Thus, the input required from the user is very simple - load intensity in the form of pressure, and the region of the structure in terms of X, Y and Z coordinates in space, of the area over which the pressure acts.
In the process of converting the pressure to beam loads, STAAD will consider the empty space between crisscrossing beams (in plan view) to be panels, similar to the squares of a chess board. The load on each panel is then transferred to beams surrounding the panel, using a triangular or trapezoidal load distribution method.
Additional information on this facility is available in example problem 15 in the help file.
