| Version(s): | All | ||
| Subarea: | Loading | ||
| Original Author: | Abhisek Mandal, Bentley technical Support Group | ||
I am using the moving load generation. The truck that I am specifying is so wide (dimension perpendicular to direction of traffic) that within the width of one lane of traffic, there are 3 or more parallel beams along the direction of traffic. How does STAAD determine how the truck load should be converted to beam loads?
Based on the data you provide under the DEFINE MOVING LOAD command, each truck is treated as a set of axles. If the WIDTH option is NOT specified, each axle is assumed to be comprised of 1 tire. If the WIDTH option is specified, each axle is assumed to be comprised of 2 tires.
The program looks at each tire independently. For any given tire, it looks for one longitudinal beam to the left of the tire, and another longitudinal beam to the right of the tire. Then it distributes the tire weight on those 2 beams as though the tire is located on a simply supported cross beam that spans the two longitudinal members on either side.
Thus, even if a lane spans across 3 longitudinal beams or for that matter several beams, the above approach ensures that the tire weights get properly applied on the correct set of beams as concentrated member loads.
You can get a listing of these concentrated member loads by using the command:
PERFORM ANALYSIS PRINT LOAD DATA
