如何将2个bim中的图形模型显示在一个视图中 我们通过TiledGraphicsProvider接口可以实现将2个bim中的图形模型显示在同一个视图中。
示例如下所示:
现有V1.bim,其预览如下所示:
有V2.bim,其预览如下所示:
我们首先在APP中加载并预览V1.bim,然后通过TiledGraphicsProvider接口,导入V2.bim中的Tile内容,即可得到如下所示预览内容:
核心代码如下所示:
async function addFeatureSymbology() {
const vp = IModelApp.viewManager.selectedView;
if (vp) {
await addProvider(vp);
async function removeFeatureSymbology() {
if (vp) {
await removeProvider(vp);
/** 对TileTree的引用源自与用户打开的对象不同的IModelConnection */
class ExternalTreeRef extends TileTreeReference {
private readonly _ref: TileTreeReference;
private readonly _ovrs: FeatureSymbology.Overrides;
public constructor(ref: TileTreeReference, ovrs: FeatureSymbology.Overrides) {
super();
this._ref = ref;
this._ovrs = ovrs;
public get castsShadows() {
return this._ref.castsShadows;
public get treeOwner() {
return this._ref.treeOwner;
public addToScene(context: SceneContext): void {
const tree = this.treeOwner.load();
if (undefined === tree) return;
// ###TODO transform
const args = this.createDrawArgs(context);
if (undefined === args) return;
tree.draw(args);
args.graphics.symbologyOverrides = this._ovrs;
const branch = context.createBranch(args.graphics, args.location);
context.outputGraphic(branch);
class Provider implements TiledGraphicsProvider {
private readonly _refs: TileTreeReference[] = [];
public readonly iModel: IModelConnection;
private constructor(
vp: Viewport,
iModel: IModelConnection,
this.iModel = iModel;
for (const kvp of iModel.models.loaded) {
const spatial = kvp[1].asSpatialModel;
if (undefined !== spatial) {
const ref = spatial.createTileTreeReference(vp.view);
this._refs.push(new ExternalTreeRef(ref, ovrs));
public static async create(
vp: Viewport,
): Promise<Provider> {
const query = { from: SpatialModelState.classFullName, wantPrivate: false };
const props = await iModel.models.queryProps(query);
const modelIds = [];
for (const prop of props) if (undefined !== prop.id) modelIds.push(prop.id);
await iModel.models.load(modelIds);
// Enable all categories (and subcategories thereof)
const ecsql =
"SELECT DISTINCT Category.Id as CategoryId from BisCore.GeometricElement3d WHERE Category.Id IN (SELECT ECInstanceId from BisCore.SpatialCategory)";
const catIds: string[] = [];
for await (const catId of iModel.query(ecsql))
catIds.push(catId.categoryId);
const subcatsRequest = iModel.subcategories.load(catIds);
if (undefined !== subcatsRequest) await subcatsRequest.promise;
// Ignore the symbology overrides defined on the viewport - instead, set up our own to draw our iModel's categories.
const ovrs = new FeatureSymbology.Overrides();
for (const catId of catIds) {
const subcats = iModel.subcategories.getSubCategories(catId);
if (undefined !== subcats)
for (const subcat of subcats) ovrs.setVisibleSubCategory(subcat);
return new Provider(vp, iModel, ovrs);
public forEachTileTreeRef(
_vp: Viewport,
func: (ref: TileTreeReference) => void
): void {
for (const ref of this._refs) func(ref);
const providersByViewport = new Map<Viewport, Provider>();
/** A simple proof-of-concept for drawing tiles from a different IModelConnection into a Viewport. */
export async function addProvider(vp: Viewport): Promise<void> {
const existing = providersByViewport.get(vp);
if (undefined !== existing) {
vp.dropTiledGraphicsProvider(existing);
providersByViewport.delete(vp);
await existing.iModel.close();
return;
const filename = Config.App.getString("imjs_offline_imodel_Next");
if (undefined === filename) return;
let iModel;
try {
iModel = await SnapshotConnection.openFile(filename);
const provider = await Provider.create(vp, iModel);
providersByViewport.set(vp, provider);
vp.addTiledGraphicsProvider(provider);
} catch (err) {
alert(err.toString());
export async function removeProvider(vp: Viewport): Promise<void> {
} else {
alert("Provider不存在.");
