| Version(s): | 10.10.00.23 | ||
| Area: | Project Navigation | ||
| Subarea: | Sheet Index |
How to remove a Sheet Model from the Sheet Index
Right Mouse click on the Sheet Model to be removed and select 'Remove from Sheet Index'. An alert appears asking you to confirm - Select OK
In the Key-In enter the following :
sheet removefromsheetindex SheetModelName
Where SheetModelName is the name of the Sheet Model to be removed. (If the Sheet Model name contains spaces put inside " ")
Expand the Sheet Index tab
Select the 'Open Sheet Index for Edit' tool on the Sheet Index tab
Navigate and select the Sheet Model you want to remove from the Sheet Index
Select the ' Delete' tool on the Sheet Index tab
Select the 'Make Sheet Index Read Only' tool on the Sheet Index tab
