private static CimClassDesc m_sDesc = new CimClassDesc(typeof(MyFirstCimObject), CimGraphicObject.Desc(), false);
new public static CimClassDesc Desc ()
return m_sDesc;
public override CimClassDesc GetDesc ()
return Desc();
public override string SchemaName
get
return "<MySchemaName>";
public override string ECClassName
get
return "<MyECClassName>";
new public static StatusInt DoRegister ()
return CimClassFactory.Instance.DoRegister(Desc());
new public static StatusInt DoUnregister ()
return CimClassFactory.Instance.DoUnregister(Desc());
protected override BentleyStatus OnGeneratePresentation (ViewContext viewContext)
// TODO: 对象绘制逻辑
return BentleyStatus.Success;
public override DTransform3d LocalTransform
get
// TODO: 添加逻辑以计算相对变换矩阵
return newPlace.Transform;
protected override StatusInt OnPreInitData ()
// TODO: 添加初始化逻辑
return base.OnPreInitData();
protected override StatusInt OnPostInitData ()
StatusInt retVal = base.OnPostInitData();
// TODO: 添加初始化逻辑
return retVal;
在包含当前类的CimModule派生类的_OnModuleLoaded()方法中执行 MyFirstCimObject::DoRegister();
