The ADINA System is now licensed in three tiers or editions, and now licensed through the Bentley Subscription Entitlement Service (SES) so there is no longer a specific need for a floating license.
ADINA Standard Edition authorizes use of the ADINA User Interface (ADINA AUI) and ADINA Structures. It also includes the ADINA-M Open CASCADE interface unless the ADINA Parasolid modeler option below is selected.
ADINA Advanced includes all standard edition functionality as well as the ADINA Thermal (ADINA-T) and ADINA Thermo-Mechanical Coupling (ADINA-TMC) solutions.
ADINA Ultimate includes all ADINA solver functionality. This includes, but is not limited to, ADINA Computational Fluid Dynamics (ADINA CFD), ADINA Fluid-Structure Interaction (ADINA FSI), ADINA Electromagnetics (ADINA EM) and other multi-physics coupling such as ADINA FSI/EM. Users of the Educational or Research version may also apply the ADINA Ultimate tier.
ADINA Parasolid Modeler is an optional Parasolid modeling module for advanced solid modeling capabilities. This requires a separate license that can be used with any tier.
The other CAD Interfaces are free with a current Bentley Systems subscription. This is activated through a license called Structural SELECT Entitlements.
The Table below compares the legacy ADINA R&D Products with the equivalent Bentley ADINA Tier
| ADINA R&D Product or Module | Bentley ADINA Tier |
| ADINA User Interface (AUI) | ADINA |
| ADINA Structures | ADINA |
| ADINA Thermal | ADINA Advanced1 |
| ADINA Computational Fluid Dynamics (CFD) | ADINA Ultimate |
| ADINA Electromagnetics (EM) | ADINA Ultimate |
| ADINA Fluid Structure Interaction (FSI) | ADINA Ultimate |
| ADINA Thermo-Mechanical Coupling (TMC) | ADINA Advanced |
| ADINA Multiphysics | ADINA Ultimate |
| ADINA Modeler OpenCascade (M/OC) | ADINA |
| ADINA Modeler Parasolid (M/PS) | ADINA Parasolid Modeler |
| FEMAP, Nastran, Simcenter NX transors | ADINA2 |
| Multiple cores (2,4,8,16,32) | ADINA3 |
| Floating License | ADINA |
For a more detailed feature/license table see ADINA Licensing Tiers Table.
