| Product(s): | CONNECTION Client | ||
| Version(s): | pre 10.00.04.17 | ||
| Area: | Access | ||
| Subarea: | N\A |
I can not login to "CONNECTION client".
Following error message appears:
Connection Faliure
User failed to login
A notification was sent through our blog requesting users to update the CONNECTION CLIENT by February 6th.
Update your CONNECTION client by February 6th!
In case, you have not updated the CONNECTION CLIENT by February 6th, you will receive the “User failed to login” error. You will need to download and install the CONNECTION client.
Please install at least version 10.00.04.21 which is available for download from the Software Downloads. Search for "CONNECTIONS".
If there is no suitable language version available, we recommend installing an English version until the preferred language version is released.
Bentley Connect - didn't update by February 6th
Unable to sign in Community Client
Cannot sign in to CONNECTION Client
German: CONNECTION Client: "Benutzer konnte sich nicht anmelden"
| Original Author: | Yvonne Lohse |
