| Version: | V8, XM, V8i, CE | ||
| Area: | Drawing Aids | ||
| Subarea: | Accudraw |
Active depth changes after each time an element is placed.
Performing a Fence File command into a new design file can fix this issue. It is a rare occurrence that this would be required but appears to correct this issue relating to problems with Active Depth.
Steps:
1. Place a fence around the elements
2. Key-in: FF=
3. Give file a name
4. Accept in view.
