OpenBridge Designer CONNECT Edition 2022 Release 1
This topic summarizes the new enhancements inĀ OpenBridge Designer (OBD) CONNECT Edition 2022 Release 1 and its components OpenBridge Modeler (OBM), RM Bridge, LEAP Bridge Concrete (LBC), and LEAP Bridge Steel (LBS). The full list of enhancements and error corrections is described in the attached document.
