| Version(s): | Connect Edition | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Steel AutoDrafter workflow | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How to draw a continuous top chord in Steel AutoDrafter.
Steel AutoDrafter module has option to group certain entity to make them a continuous member. Here a short video is attached to demonstrate the workflow.
