| Version: | V8, XM, V8i, CONNECT | ||
| Area: | DWG | ||
| Subarea: | General |
The capability to reference a DXF file into another DXF file has been removed by default.
The following capability can be added to the workspace configuration files to include this operation in Microstation, please contact your site administrator to set the variable at the appropiate configuration file:
_USTN_CAPABILITY_DWG < +CAPABILITY_REFERENCE_ALLOW_DXF
Please refer to help documentation "Enabling and Disabling Workmode Capabilities" for more information on setting MicroStation capabilities.
Other Languages
| Original Author: | Andrew Bell |
