| | Applies To | | |
| | Product(s): | STAAD.Pro | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | STAAD.Pro Licensing Solutions | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
The TechNotes and FAQs in this section cover various topics that pertain to the licensing of STAAD.Pro.
- List of Programs included in different types of License for STAAD.Pro
- STAAD Product Releases in December 2018 and Associated Licensing Changes
- [[Which License Should I Choose When Using RCDC?]]
- [[Advanced Concrete Design is now Included with STAAD.Pro License]]
- [[When the license in Staad Pro shows in Trial , Offline mode]]
- [[Structural SELECT Entitlements]]
- [[SELECT Server Licensing]]
- [[Bentley License Management Tool]]
- [[How is STAAD.Pro licensed]]
- [[Starting STAAD.Pro]]
- [[Do I need to register to Connect services to use STAAD.Pro CE]]
- [[STAAD.Pro CONNECT Edition Licenses]]
- [[Product Activation]]
- [[How to reserve a STAAD.Pro license for offline usage]]
- [[If Connection Client fails to login]]
- [[Connection Client]]
- [[CONNECT Licensing]]
- Enable Ram Connection License with STAAD.pro CONNECT Edition
- [[Configure STAAD.Pro CONNECT edition for Advanced Analysis]]
- [[Unable to activate RAM Connection license from STAAD.Pro]]
- [[STAAD.Pro shows 'Checking Licenses', stalls for a minute and then closes]]
- [[How do I check that I'm using STAAD.Pro Advanced?]]
- [[My company has one license of STAAD.Pro; can I use it in a desktop and a laptop?]]
- [["Trial/Valid license was not found" message still appears even when licenses are available]]
- [[Move STAAD. Pro License to New Machine]]
