| Version(s): | 08.11.07.171 | ||
| Area: | Text | ||
| Subarea: | Text Styles | ||
| Original Author: | Juan Contreras, Bentley Technical Support Group | ||
Remap text styles in existing DGNs
Product: MicroStation V8i
Version: 08.11.07.171
You can convert existing text styles to new text styles by:
(1) Open the Elements > Text Styles dialog box.
(2) Select the style(s) - press and hold Shift to select multiple styles - you want to change and choose the option "Remap Elements".
(3) Select the Style you want to remap the text to in the "Destination" drop down list and press Ok.
