| Version: | V8i, CONNECT | ||
| Area: | Text | ||
| Subarea: | Text Styles |
How to enable text justification.
In Text Styles justification can be defined in a text style, then applied to the text element.
Element > Text Styles:
Justification can also be applied to Dimension Styles:
Element > Dimension Styles > Text
Element > Dimension Styles > Advanced > Notes > Justification
| Original Author: | Derval Canny |
