In the Recalc Window at the Non-linear Analysis inside the Basic Settings, the user can select the multiple possible options for the consideration of the non-linearities in the modeled structure:
The importance of being able to turn them on and off is to isolate non-linear effects. Some specific elements can be switched off by setting the respective options to No in .
communities.bentley.com/.../rm-bridge-analyzer-recalculation-window
