| Environment: | ALL | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Installation | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How do I download latest version of STAAD.Pro?
Answer:
1. Open a browser in your system with internet connection.
2. Go to https://connect.bentley.com/
3. Log in in the page with your credentials.
4. (Optional) If it requires any other permission, please provide.
5. Now, go to the bottom of the page and you will find Software Download option as shown below.
6. Click on Software Download option and it will open software download page as shown below.
7. Now, type the product name in "Search by product name" box. You will find some softwares in the page. If you get the software you were looking for then click on "GET SOFTWARE" option below that software. Else, you can search the software using search box as marked above. If you know the product line and brands then you can search for them directly from the dropdown as shown below.
8. Now clicking on the get software option will show you the below page. Set the required filled from the dropdown and click on apply. Then click the download button as shown below.
9. Keep this installer in a folder as per your requirement.
10. You can use this installer to install the software. To install the software, right click on the installer and choose the Run As Administrator option. If you want to know more about the installation process, double click on the installer and click on the question mark (Help) at the right top corner of the installer window.
Refer STAAD.Pro CONNECT Edition Installation for installation guidelines.
