Column Cap Joints
In RAM Connection, Column Cap (CC) Joints can be created with the following configurations:
Shear & Moment Connections
Connector
| Design Code | Column Section | Beam Section |
Joint/Connection Options
- AISC: Cap Plate (CP)
- AS: Cap Plate (CP)
- CSA: Cap Plate (CP)
- EN: Cap Plate (CP)
- NZS: Cap Plate (CP)
- Stiffeners: Transverse Stiffeners Optional
Gusset Connections for Column Cap Joints
Connector
| Design Code | Column Section | Beam Section | Brace Section |
- AISC: Cap Plate - Brace (CCB)
- Channel
- Rectangular
- Angle/Double Angle
- Circular
- I-Shaped
- Tee-Shaped
