Hebrew text, inside Word Processor is mirrored
 Product(s):MicroStation
 Version(s):08.11.09.829
 Environment:N\A
 Area:Text
 Subarea:Word Processor
When editing, Hebrew text elements that use certain SHX fonts "0-MIRYM_W, 0-Techno", text appears mirrored in the Word Processor dialog.
Set the Code Page value for the SHX fonts “0-MIRYM_W, 0-Techno” to Hebrew “1255”
•  Open MstnFontConfig.xml from location C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\Fonts\
•  Make a copy of the file (ZIP the file).
•  Open MstnFontConfig.xml in a Text Editor
•  Under the ShxFontInfo section add the following lines
   <!-- Hebrew SHX fonts. -->
   <ShxFontInfo>
       <Name>0-MIRYM_W,0-Techno</Name>
       <CodePage>1255</CodePage>
       <Hidden>False</Hidden>
       <CreateEditorTempFont>False</CreateEditorTempFont>
   </ShxFontInfo>
•  Save the file
•  Re-open MicroStation.
Other language sources
Hebrew text is not displayed correctly
 Original Author:Leonard Jones
