Designing Beam-to-Support Connections in RAM Connection
Designing Shear Connections
Learn how to design shear connections for beam-to-support joints RAM Connection Standalone.
Designing Moment/Combined Connections
Learn how to design moment connections for beam-to-support joints in RAM Connection Standalone.
Knowledge Base
In RAM Connection, each of the connection templates is compatible with certain connection configurations, including the support and beam sections that are permitted. Use the resources below to review the beam-to-support connection configurations that are available:
For additional information, see the following technical discussions and wikis:
Additional Resources
Want to learn more? See the additional resources for RAM Connection.
 Knowledge Base Articles RAM|STAAD Forum RAM Ideas Portal RAM Connection Product Page
 RAM Connection Training RAM Connection Technical Discussions RAM Connection Tips and Tricks
 RAM Coffee Corners
(NAOU)
STAAD/RAM Coffee Corners
(EMEA)
STAAD Coffee Corners
(NAOU)
(SEAPAC)
Need help? Connect with us using the Bentley Support Portal.
