Designing Splices in RAM Connection
Designing Beam Splices
Learn how to design beam splices in RAM Connection Standalone.
Designing Column Splices
Learn how to design beam and column splices for moment reactions in RAM Connection Standalone.
Knowledge Base
In RAM Connection, each of the connection templates is compatible with certain connection configurations, including the support and beam sections that are permitted. Use the resources below to review the beam splice and column splice configurations that are available:
For additional information, see the following technical discussions and wikis:
Additional Resources
Want to learn more? See the additional resources for RAM Connection.
 Knowledge Base Articles RAM|STAAD Forum RAM Ideas Portal RAM Connection Product Page
 RAM Connection Training RAM Connection Technical Discussions RAM Connection Tips and Tricks
 RAM Coffee Corners
(NAOU)
STAAD/RAM Coffee Corners
(EMEA)
STAAD Coffee Corners
(NAOU)
(SEAPAC)
Need help? Connect with us using the Bentley Support Portal.
