Designing Column Top and Base Connections
Designing Column Cap Plates
Learn how to design column cap plates in RAM Connection Standalone.
 Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Designing Column Base Plates
Learn how to design column base plates in RAM Connection Standalone.
  and   Download the Project Workbook and Dataset from the Bentley LEARN Server for hands-on, step-by-step instructions.
Key Features
In RAM Connection, each of the connection templates is compatible with certain connection configurations, including the support and beam sections that are permitted. Use the resources below to review the beam splice and column splice configurations that are available:
Technical Discussions and Wikis
For additional information, see the following technical discussions and wikis:
Additional Resources
Want to learn more? See the additional resources for RAM Connection.
 Knowledge Base Articles RAM|STAAD Forum RAM Ideas Portal RAM Connection Product Page
 RAM Connection Training RAM Connection Technical Discussions RAM Connection Tips and Tricks
 RAM Coffee Corners
(NAOU)
STAAD/RAM Coffee Corners
(EMEA)
STAAD Coffee Corners
(NAOU)
(SEAPAC)
Need help? Connect with us using the Bentley Support Portal.
