RM Bridge Results Options are definitions for the results to be presented as graphics in the current graphics windows view. The structure model results presentation can be scaled and is grouped into five different display types:
- Deflected Structure: with the displacements;
- Support Reactions: with the ground support elements and nodes reactions;
- Colored Faces: with colored faces and shading;
- Diagram: elements results as plotted curves;
- Influence Lines: lines of influence with the traffic lane and respective load train.
