Product(s): |
MicroStation |
Version(s): |
08.11.09.459 |
Environment: |
N\A |
Area: |
Animation |
Subarea: |
General |
Original Author: |
Craig Calvin, Bentley Technical Support Group |
This video demonstrates how to animate a fading effect by scripting element transparency.
Support Video Clip
www.youtube.com/watch
- Select the elements
• Doing this step before selecting the Script Element Attribute tool allows the element selection tool to be used.
- Select the Script Element Attribute tool
To Access
• Tasks: Animation > Animation Properties > Script Element Attribute
• Menu: Tools > Animation > Animation Settings > Script Element Attribute
• Key-in: ANIMATOR ANIMATE ELEMENTATTR
Tool Settings
• Setting: Transparency
• Start Time: (Adjust as required)
• Transparency: (Adjust as required)
- Click a data point to accept
Repeat steps 2-3 to script the element transparency at different times as needed.
Note: Animating transparency of elements with materials is discussed here.
Product TechNotes and FAQs
External Links
Bentley Technical Support Knowledge Base
Bentley LEARN
