| Product(s): | MicroStation PowerDraft | ||
| Version(s): | 08.11.07.443 | ||
| Area: | Other | ||
| Subarea: | N\A | ||
| Original Author: | Derval Canny, Bentley Technical Support Group | ||
Setting a color table for use in a specific project, and description of the use of Colour Tables in Reference files.
Configuration settings need to be set to point to your colour table:
Workspace>Configuration>Colors>Default Color Table
Regarding references and color tables, there are two options
Under:
Preferences->Reference
When "Use Color Table" is toggled "OFF",
all references are displayed using the currently attached color table of the "Active File"
Under:
If you have "Use Color Table" toggle "ON",
all references use the color table stored in their individual reference files.
Therefore, if each reference file has a different color table stored in it, it would display differently.
http://communities.bentley.com/products/microstation/f/19565/t/47229.aspx
Other Language Sources
