| Version(s): | 08.11.07.443 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Configuration | ||
| Subarea: | DGN Settings | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
Turning ACS Triad on/off through keyins
To turn on the ACS triad in all open MicroStation views type:
set acsdisplay on;selv all;update all
To turn off the ACS triad in all open MicroStation views type:
set acsdisplay off;selv all;update all
Make sure "Start in Parse All Mode" is turned on under
Workspace>Preferences>Category
Other Language Sources
