Fields - Text - MicroStation
Text Fields
Adding / Editing Fields placed inside a Text string.
Automatically Update Text Fields
Drop text fields to regular text
Inserting Fields in Text
Text Fields - Auto Updating Annotations
Text Fields not automatically updating
Text in cells is disappearing when saved to DWG
Update Text Fields Automatically
Data Fields
Add Enter Data Fields to Existing Text
Can not edit datafields that are inside cells
Enter Data Fields (EDF) in shared cells ...
How to change the order through which enter data files (EDF) are cycled with the Auto Fill In Enter Data Fields tool.
How to create a Data Field in MicroStation v8.
How to edit properties on enter data field?
How to get underscore working either as data field or as an underscore in the same model.
How to re-order data fields
Insert Data Field in Existing Text
Using the Edit text tool for enter data fields
