| | Product(s): | MicroStation | |
| | Version(s): | 10.12.00.40 | |
| | Environment: | N\A | |
| | Area: | Dimensions | |
| | Subarea: | Labels | |
How to label the position of an element with its 'Z' coordinate value.
- Open the Key-in dialog if not already open ( Drawing > Home > Primary > Key-In )
- In the Key-In enter label hidexy off
- Select the Lable Element Coordinates tool from the ribbon ( Drawing > Annotate > Terrain Model > Label Coordinates )
- Optional - Change the Tool Settings as required
- Snap to the Elements location to place the label.
Note: To return to the default of having the X,Y & Z values enter the keyin label hidexy on. Alternatively the keyin label hidexy toggle can be used.
