DWG block attributes as Tags Or Item Types
 Product(s):MicroStation
 Version(s):10.00.00.25
 Environment:N\A
 Area:DWG
 Subarea:Open
How can we retain DWG Block Attributes as Tags OR Item Types in MicroStation Connect Edition.
This video demonstrates how a DWG Attribute Block can be converted to MicroStation Tags. By default the DWG Attribute Block is converted to Item Types.
Video
 www.youtube.com/watch
Thanks to Rick Ruth for this video.
 Original Author:Leonard Jones
