This topic summarizes the new enhancements in OpenBridge Modeler CONNECT Edition v10.12.01.xx
- Model Single Beam in Beam and Slab type Bridges
- Model Barriers on Wing Walls
- Specify Barrier End Cut Orientation at each end
- Improved Bearing Elevations (Properties and Reports)
- Automated 2D Decorations for Bearings and Bearing Seats
- Transverse Offset for Wing Walls
- Expanded Steel Tubs Properties
- Field Splice: Inner Splice Plate now optional
- Improved Superstructure C/S Drawings, PGL and Slope
- Accurate Modeling of Haunch for Open Concrete Tubs
- Option to Slope Crown Cap Bottom
- Improvements to Footing Elevation Constraints and DTM
- Option to Slope between Bearing Seats
- Skew Solid option for Tapered Caps and Inverted Tee Caps
- Improvements in Generative Components workflow
- Accurate Excavation for Custom Footings
- Misc. Enhancements (minor):
- Show Direction/Bearing in Pier/Abutment Report
- New option for “Create HEC-RAS Data” under Civil Analysis
Technology Stack:
- MicroStation PowerPlatform Update 17.2 (v10.17.2.454)
- Civil Platform (10.12.1.169)
- OpenRoads 2022 Release 2 (v10.12.1.59)
- ProStructures Update 7.2 (v10.07.2.18)
- Certified with PW v10.00.03.453
- Generative Components (v10.17.2.18)
- GINT (10.7.1.1)
- Descartes (10.17.2.61)
- CONNECTION Client (11.00.05.44)
YouTube playlist:
https://www.youtube.com/playlist?list=PLTXGGjuaGicgDCzzcCsbOV5cFGe2d_bJO
