Issue Number |
Description |
1176842 |
Beam lines on a curved alignment are transferred to LBS as tangent |
1223139 |
Update bridge with multiple units causes OBM objects to go missing |
927547 |
OBM files getting incorrectly branded as ORD when Civil elements are copied in |
1024855 |
Incorrect direction value reported for steel beams |
1087891 |
Custom pier: missing concrete pad material |
109722 |
Crash when column template (variable columns) is missing |
1178955 |
Direction in beam report, display as bearing not working |
1127045 |
Barriers on wing walls not supporting variation |
1127230 |
Bearing seat thickness issue for bridge created with wizard |
1169111 |
Zoom problem in 3D model, view turns blank |
1178649 |
Missing Bridge description in input report |
1181149 |
Large haunch issue for curved concrete U girders |
1209150 |
MDL loader error when switching workspaces |
1210704 |
Error placing wing walls |
1211972 |
Place custom abutment/pier causing crash. File specific issue |
Issue Number |
Description |
1211979 |
OBM to LEAP interop error due to CG set as centerline reference |
1218513 |
Beam layout generates CIF exception error |
1219924 |
Cap depth entered in template is not matching accurately with model |
1228122 |
Input echo report not working for custom deck template |
1228938 |
Fix cap length when apply skew solids in set to True |
1235009 |
Crash when column fillet is exactly half of column depth |
1235271 |
For Super Tee beams, external beam haunches were generated over opening |
1236826 |
Improve accuracy of column under crown point of cap |
1244894 |
Improve performance of move bridge command |
1260648 |
Approach slab was missing in quantities chart |
1265883 |
Missing station for Piers and Abutments, including item types |
1269046 |
Missing elevation constraints for footings in input echo report |
1258965 |
Incorrect material in quantities report for filled pipe piles |
1312038 |
Failed to generate Steel Tub girders in certain cases |
1327647 |
Failed to generate Steel Built-up Beams in certain cases |
