| | Product: | MicroStation | |
| | Version: | 08.11.09.459 | |
| | Environment: | N\A | |
| | Area: | DWG | |
| | Subarea: | Open | |
Error or Warning Message
Unable to locate and open seed file required to open this file. Check the MS_TRANSEED configuration variable."
Explanation
Attempting to open DWG / DXF or a master file a referenced DWG / DXF file.
How to Avoid
Option #1- Define the MS_TRANSEED Variable
- Go to Workspace > Configuration > Seed Files category
- Look up "DWG Seed File"
- Click "Select"
- Browse to the location of a valid transeed file
- Save configuration
Option #2 - Reset settings
- Go to path defined by MS_DWGDATA for example by following key in: $ % explorer $(MS_DWGDATA)
- Close MicroStation
- Delete dwgsettings.rsc file
This file will be regenerated the next time a file is converted to DWG or DWG file is open and "Options" button is invoked and making a change to the settings.
Option #3 - Selecting translation seed file
- From MicroStation Open dialog select DWG / DXF file
- Click on the Options button
- Go to the Basic section
- Go to the "DGN Seed File:"
- In Value column select the current value and then browse to location of desired seed file
- Choose the file and click on the "Open" button
This will override the path set in MS_TRANSEED variable.
See Also:
communities.bentley.com/.../15370.unable-to-open-seed-file-seed-dwg
Other Language Sources
Deutsch
| | Original Author: | Reginald Wallace | |
