ADINA provides comprehensive linear and nonlinear finite element analysis of solids, structures, and fluids leading to greater safety, resiliency, and economy. In ADINA, structures, fluids and heat transfer can be combined to provide increased accuracy when this is required. Hence, it is possible to combine structures with fluids in fully coupled fluid-structure interaction analyses, couple the heat transfer with either structures or fluids, or even solve all three physics (structural, thermal and fluid) in one single thermal fluid-structure interaction model. Acoustics, pore pressure, electromagnetism and others are also supported, and can be included in full Multiphysics models.
The ADINA Resources are available to show you the complete workflow for working with ADINA.
