ADINA provides comprehensive linear and nonlinear finite element analysis of solids, structures, and fluids leading to greater safety, resiliency, and economy. In ADINA, structures, fluids and heat transfer can be combined to provide increased accuracy when this is required. Hence, it is possible to combine structures with fluids in fully coupled fluid-structure interaction analyses, couple the heat transfer with either structures or fluids, or even solve all three physics (structural, thermal and fluid) in one single thermal fluid-structure interaction model. Acoustics, pore pressure, electromagnetism and others are also supported, and can be included in full Multiphysics models.
The ADINA Learning Resources are available to show you the complete workflow for working with ADINA.
Learn how to navigate the ADINA Graphical User Interface.
Learn how to model structures in ADINA.
Learn how to design structures in ADINA.
Learn how to use ADINA to perform an advanced analysis for a RAM Structural System model or a STAAD.Pro model.
For additional information, see the following technical discussions and wikis:
Want to learn more? See the additional resources for analysis topics in ADINA.
Knowledge Base Articles | ADINA Forum | ADINA Ideas Portal | ADINA Product Information | |
STAAD Coffee Corners (NAOU) |
STAAD/RAM Coffee Corners (EMEA) |
STAAD Coffee Corners (SEAPAC) | RAM Coffee Corners (NAOU) |
