| Version: | V8i, CONNECT | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
How to be able to always have the same seed file used.
The variable MS_DESIGNSEED can be set and then use a % lock to lock the variable so that it value is always set as the default.
