Solution for Issues Related to Etabs-RCDC Workflow
Product(s):
STAAD Advanced Concrete Design
Version(s):
Connect Edition
Environment:
Area:
Concrete Design
Subarea:
Original Author:
Abhisek Mandal, Bentley Technical Support Group
[[Story forces and Story drifts data are missing when importing .accdb file into RCDC]]
[[General reading type of error in RCDC .]]
[[Unable to Import the Wall elements from ETABS 2019 / ETABS 2020 MDB Files]]
[[RCDC can import only the database *.accdb created from any version of ETABS.]]
[[Data exported from Etabs in FPS foot-pound-second reflects in RCDC as MKS meter-kilogram-second]]
[[Error while Exporting file from ETAB's]]
[[Etabs procedure for 3 steps MDB and merging]]
[[General reading error in RCDC, Input table or Frame Assignments-output stations]]
[[Unable to import the Etabs 2019 Model TO RCDC]]
[[Unable to import wall from Etab's model to RCDC]]
[[Direct linking RCDC to Etabs]]
[[Unable to import the Etabs 2019 Model]]
[[Direct linking RCDC with Etabs 18 ]]
[[Unable to Import Etab’s 17 and higher Version EDB file in STAAD RCDC.]]
[[Linking with ETAB's version 15 & 16]]
[[How to avoid Duplicate data in MDB file.]]
[[Facing issue to perform column design.]]
