For Analytical Insights Technology Preview, model upload is enabled only from desktop. Learn more about accessing Analytical Insights from RAM Structural Systems from this link
You can access existing models in a CONNECT Project from Optioneering Center.
- Choose CONNECT Project under which the model is uploaded
- Select Optioneering Center tile from Project Portal
- Choose RAM Structural System Tile from Analytical Insights
- Choose model version to proceed to Insights
