| Version: | V8 | ||
| Area: | DWG | ||
| Subarea: | General |
Would like to set up Workspace so DWG/DXF Units dialog is automatically turned off.
Go to File->Open select (make sure file type is set to dwg or dxf) dwg options go to advanced -> dislay units and toggle all off. This will save to the dwgsettings.rsc. Copy this file to network and set Configuration variable MS_DWGDATA to the file path in the workspace. Now when the users open MicroStation they will automatically be set not to show this dialog box.
DWGSETTINGS.rsc is located in the C:/Program Files/Bentley/Home/prefs/dwgdata
