| Version: | V8 | ||
| Area: | Configuration | ||
| Subarea: | Workspace |
Made a change to the Mslocal.cfg file and now gets" Unexpected end of macro error"
The Mslocal.cfg file did not have a carriage return after the last line. Once it was added, MicroStation started.
