| Version: | V8 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
When setting up MS_DEF in a project configuration file, the project directory is coming up wrong and is doubled.
The path to MS_DEF did not have a trailing back slash at the end. Once trailing back slash was added problem was resolved.
