| Version(s): | All | ||
| Area: | OpenSTAAD | ||
| Subarea: | Steel Design | ||
| Original Author: | Bentley Technical Support Group, Shreyanka Bhattacharjee | ||
Problem Description:
How to assign STEEL CHECK CODE command using OpenSTAAD function
You can use function AssignDesignCommand
Using the same function, TAKE OFF, GROUP/FIXED GROUP/SELECT/SELECT OPTIMIZED command can also be assigned.
Parameter:
[Input] nBriefRef: The Design Brief reference ID.
[Input] strCommandName: Design command name.
[Input] strCommandValue: Parameter for design command.
[Input] varMembers: Number ID of Member(s) to be assigned to.
Sample VBA Syntax:
Set objOpenStaad = GetObject(, "StaadPro.OpenSTAAD")
Dim nBriefRef As Long
Dim strCommandName(5) As String
Dim strCommandValue As String
Dim varMembers(3) As Long
nBriefRef = 1 'Parameter Block Number
strCommandName(0) = "CHECK CODE"
'strCommandName(1) = "TAKE OFF"
'strCommandName(2) = "GROUP"
'strCommandName(3) = "FIXED GROUP"
'strCommandName(4) = "SELECT"
'strCommandName(5) = "SELECT OPTIMIZED"
strCommandValue = ""
varMembers(0) = 2
varMembers(1) = 4
varMembers(2) = 5
varMembers(3) = 7
objOpenStaad.Design.AssignDesignCommand nBriefRef, strCommandName(0), strCommandValue, varMembers
