| Product: | MicroStation | |
| Version: | V8i, CONNECT | |
| Environment: | N\A | |
| Area: | Selection | |
| Subarea: | General |
When in MicroStation, hovering over an element causes it to highlight to a different color, but the element stays highlighted until the view is either zoomed in, zoomed out, or refreshed.
The following solution resolves the issue:
| Original Author: | Judy Wong |
