| Version: | V8i | ||
| Area: | Feature Based Solids Modeling | ||
| Subarea: | General |
The "Intersection Curve" option on the Trim Surfaces Tool is missing.
In Microstation V8 XM Edition the Intersection Curve was an option on the Construct Trim Tool.
Tools > Surface Modeling > Modify Surfaces > Construct Trim > Intersection Curve
Intersection Curve has now been separated into it's own Compute Intersections tool
In V8i, this tool now available as its own tool and on the Surface Utilities Toolbox.
Tools > Surfaces > Surface Utilities > Compute Intersections
| Original Author: | Melissa Koval |
