What is a Structural Performance Indicator (SPI)?
It is a practical design rule capturing your office's best practices.
SPI lets you define how you want to measure the performance of the engineering model. You can take advantage of predefined SPIs available with Analytical Insights or you can create your own.
You can define an SPI in 3 easy steps -
P.S. - You can also select special characteristics about the element e.g. lateral framing beams, gravity only columns etc.
Here are list of existing SPIs in Analytical Insights -
| Steel Beams | ||
| Gravity steel beam weight | Project specific threshold | |
| Lateral steel beam weight | Project specific threshold | |
| Reuse of steel section | Project specific threshold | |
| Camber for steel beams | Minimum camber should be 3/4 inch | link |
| Camber for steel beams | Camber should be multiple of 1/4 inch | link |
| Web thickness of cambered steel beams | Web thicknesses of Cambering of members should be more than 1/4 inch. Lower web thickness can lead to web buckling | Steel Design Guide 23: Constructability of Structural Steel Buildings - Page 18 |
| Span to Depth Ratio | Span to depth ratio should be between 20 to 28 | link |
| Flange to Depth Ratio | Project specific threshold; lower is better | link |
| Material Availability | Project specific threshold; readily available sections are better for constructability | Steel Design Guide 23: Constructability of Structural Steel Buildings - Page 9 |
| Concrete Beams | ||
| Span to Depth Ratio | Span to depth ratio should be around 5 | link |
| Depth to Width Ratio | Depth to width ratio should be around 2 | link |
| Steel Columns | ||
| Gravity steel column preferred sections | Favor W12 and W14 sections | link |
| Gravity steel column sections to avoid | Avoid W10 and W8 | link |
| Steel column flange/depth ratio | Project specific threshold; lower is better | link |
| Column Orientation | Less variation in column orientation leads to better constructability | Steel Design Guide 23: Constructability of Structural Steel Buildings - Page 9 |
| Column Length | Maximizing column length minimizes number of column shaft leading to better constructability. There are other governing factors on column length such as shipping restrictions, total weight of column, erection sequence | Steel Design Guide 23: Constructability of Structural Steel Buildings - Page 9 |
| Connections | ||
| Baseplate Shape | Use Square based plate where possible. It is easy to detail fabricate and erect | link |
| Connection Type | Prefer bolted connection over welded connection when possible. It is expensive to build, needs additional inspection and pose more construction safety hazards | link |
| Surrounding Clearance | Enough clearance should be available around connections to facilitate smooth and safe installation | link |
| Connection Angle | Avoid skewed connections where possible. It is expensive to build and pose more construction safety hazards | link |
| Weld Type | Avoid CJP weld when possible. It is expensive to build and pose more construction safety hazards | link |
| Foundations | ||
| Area of foundations | Area of isolated footings should be less than 50% of building footprint | link |
| Reinforcement | ||
| Beam & Column reinforcement size | Use fewer, larger bars than more, smaller bars, while still meeting the crack control requirement | link |
| Beam reinforcement size | Repetition in bar sizes and patterns speeds up installation | link |
| Beam & Column reinforcement spacing | Where possible spacing of longitudinal bars should be 6 in apart | |
| Road Bridges | ||
| AASHTO, AREA |
Watch SPI setup in action in Analytical Insights -
Looking for more SPIs ?
