| Version(s): | V8i & CONNECT Edition | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Licensing Solutions | ||
| Subarea: | N/A | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
Description
I have node-lock licenses to use STAAD.Pro and RAM Connection. I am successfully checking out the licenses, but RAM Connection from STAAD.Pro is giving me licensing error.
To use RAM Connection from STAAD.Pro, when you check out licenses, the version info for Ram Connection has to be the same as version of STAAD pro, This will work to run Ram Connection standalone version.
