| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Licensing Solutions | ||
| Subarea: | N/A | ||
My company has one license of STAAD.Pro V8i; can I use it in a desktop and a laptop? Can the program be installed in multiple machines? How can I switch computer if we have one license?
If your company has one license of STAAD.Pro, you can use it for one simultaneous use. You can install it in your desktop for use in the office and you laptop to use at your home. Make sure that when you leave your office, exit from STAAD.Pro; this will release the license and you can use it in your laptop.
The program can be installed in multiple computers. One license can be used at a time.
To switch computer, if you have one license, you will install STAAD.Pro in both the machines, configure the license and exit from the program before you use it in the second machine.
